1 - 6 of 6 Posts
Can anyone give me some info on a JD 450 tiller. How wide is it, what is it compatible to for a tractor( horse power requirements). Don't want to travel 200 miles to find out it won't fit.
Will the 450 Tiller work on a 2305?
Just passing through
john Deere 450 Tiller
Tilling width . . . . . . . . . . . . . . . . . . . . . . . . . . 50 in. (1270 mm)
Rotor diameter. . . . . . . . . . . . . . . . . . . . . . . . .14.5 in. (368 mm)
Rotor length . . . . . . . . . . . . . . . . . . . . . . . . . . 50 in. (1270 mm)
Rotor and counter shaft bearings . . . . . . . . . . . . Sealed ball bearings
Drive . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Tractor 540-rpm PTO
Rotor rpm. . . . . . . . . . . . . . . . . . . . . . . . . . . . 238 rpm
Rotor tip speed . . . . . . . . . . . . . . . . . . . . . . . . 903 ft./min. (276 m/min)
Height of lift . . . . . . . . . . . . . . . . . . . . . . . . . . 73⁄4 in. (197 mm)
Tilling depth (maximum). . . . . . . . . . . . . . . . . . . 7 in. (178 mm)
Weight (approx.) . . . . . . . . . . . . . . . . . . . . . . . 332 Lb. (151 kg)
Sure seems like a 2305 can handle it...;0
Thanks guys. Unfortunately I lost out on getting one today for $750 never used. I couldn't get off work until 7pm and someone took it off the guys hands 10 minutes after I talked to him on the phone.
The search continues...
1 - 6 of 6 Posts
