If you have color coded caps on the female couplers (tractor ports) use this:
Yellow: connect to angling cylinder front hose.
Silver/Gray: connect to angling cylinder rear hose.
Black: Lift cylinder top hose.
Green: Lift cylinder bottom hose.
If you have no color coded caps on the tractor ports use this as reference:
Yellow= inboard upper port.
Silver/Gray=outboard upper port.
Black=inboard lower port.
Green= outboard lower port.
