1 - 9 of 9 Posts
Hello, does anyone know if this blade will fit a John Deere 425? It sure looks like it will but I'm confused by the 4100 on the label.
2471525
2471526
I'd say the hitch fits a 4100 & is too narrow for 425 445 455. with the correct hitch that blade would fit.
  • Like
Reactions: Zagar
Burned300 is correct. The hitch will not fit. It will fit the following with the correct mounting hardware. 2320, 2520, 2720 & the classic 2025R & 2032R.
  • Like
Reactions: Tractorman425
2472430
Thank you for the responses. Do you guys know how I can ensure that this tiller is for the 425?
If it has a 3 point hitch hookup & a pto driven pump, it should work. A dealer should be able to give a clear answer with the serial number.
  • Like
1 - 9 of 9 Posts
