1 - 3 of 3 Posts
I have a hydro leak in the 4100 that I just purchased. Is there 2 separate oil systems for the loader and 3 point versus the HST system? I know there is a separate steering pump but not concerned with that no leaks up front.
I don't see any thing in the online manual other than the dipstick on the side of the seat and that level is fine. The leak appears to be coming from the rear of the tractor running down the lines that are near the mid power take off. Just want to be sure I don't run low on fluid and have checked all levels properly??
Thanks
Rob
The hydraulics, steering and transmission all use the same oil reservoir. Only one place to check. The front axle is separate and of course the engine is separate.
1 - 3 of 3 Posts
