1 - 13 of 13 Posts
I am looking to replace my JD 335 with something that can work a little harder without spending to much cash. I found a JD 400 (with 3 point hitch!!) I haven't seen it in person, but the seller told me it ran fine when he parked it. All 4 tires are shot! He has the sheet metal for the sides of the engine. At this point, that's all I know... I assume it has an hour meter? He want's $1300 for it. Does this seem like an OK deal providing it starts and goes both forward and backward? If it works out, I hope to find a loader for it.
2464321
Discussion Starter #2
The more I think about it, the more I think I'll keep the 335!! If it had a 3 point hitch I wouldn't consider getting rid of it
It will be hard hunt to find the loader for a 400. I bought mine with loader and spent two years trying to find the tiller. I would buy or make 3 point hitch for the 335.
I didn't know it was possible to have a 3 point on the 335?
You would be money ahead to look for a 425, 445, or 455 with a loader. That 400 is most likely to be a money pit. Just because it ran when parked doesn’t mean it’ll be easy to bring it back. Also, trying to make the 335 a loader and 3 point tractor will get expensive and possibly tear it apart with heavy use.
I've owned two 400's and they are the freaks of the JD world. Nothing will fit them except 400 implements. I had one with a Johnson 10 loader on it and one with a JD 20, which was essentially a Johnson 12. They have several weak spots and there are no new parts for it that are for the frame and running gear. The rear end is like a rock and will last forever. The PTO is a Rube Goldberg contraption that defies engineering. To run anything from the rear requires a long driveshaft from the front to the rear! It has an old iron block Kohler engine in it that parts are almost nonexistent. If you could get it for $400 to $500 dollars then you could repower it with a modern engine. It is a great strong frame and tranny.
Just picked up this one for $400. Runs smokes some. Faded paint buffed up nice. Gonna pull the heads to check rings. Most likely needs a valve job. Gonna put 3 point on it.
Sent from my Pixel 2 using Tapatalk
I'd say you got a "Smoke'n deal!!" No pun intended
Rephrase for clarity: "It ran fine the last time it ran fine".
1 - 13 of 13 Posts
