Greetings! Back again with another 345 fire... this time the fire did not damage the tractor much and it still runs great. Now for the source of the fire which I believe to be an oil leak somewhere, it has been intermittently smoking for a few months. This is a 900 hour 345 with the 20hp.
Before you say it is a valve cover gasket (which is what I was thinking too initially) not so fast. I just replaced the gaskets with the flat type and metal covers last year. It could be the valve cover but there was a ton of dark brown ?oil? leakage from much higher up coming from the front above the carb and coolant hose, on the right side and left above each head... trouble is I'm not sure if this is just from a mixture of water (from putting the fire out) and 20 years of grime or a leak??? I pulled the radiator/air intake/flywheel and this is what I see. (I did use penetrating oil on the flywheel so that could explain the oil on the crank shaft seal)
So, do I do the breather cover seal, breather cover, and Crank shaft seal.... or not? I'll probably add a little RTV to each side of my valve covers for good measure but I'm really not convinced they have anything to do with this...
Not sure if this is related but whenever I change the oil it looks a little suspicious ?milky? and the coolant is always a little less clear than it ought to be. Probably needs head gaskets but I've chosen to keep an eye on it and just change the coolant and oil more frequently in the short term.
