John Deere 318
983 Views 4 Replies 4 Participants Last post by  biker3777
Does anyone know the RPM from the rear shaft out of the transmission for the rear pto.I need to find what is the rpm Thank You
Toolmaker1045(Norm):greendr:
The rear pto-powered attachments for a JD 318 (such as the tiller) are 2000 rpm designed. All of JD's GTs of that era used a 2000 rpm rear pto, such as the 318, 332, 420, 430, etc.
I need the RPM out of the pump (before PTO unit) Rear
Norm
only speed shown in manual for Rear PTO is 2000 rpm. It does not show a stub shaft speed.
Since the pump is a direct drive from the engine it will be relitive to engine speed?You can see the shaft from the back,mark the shaft,turn the engine 1 turn over by hand and check the mark,I'm thinking 1 to1 ratio.Toolmaker also (Retired)
