This John Deere AM104895 PTO (Ogura) clutch is used on John Deere garden tractor models 316, 317, 318, 330, 322 and 332. The PTO clutch is in good condition. I cleaned the clutch faces and greased the bearing. The JD part # is AM104895 $650 for a new one. (SUB FOR AM39209, AM100846 AND AM101136)
Included with the clutch are the 4 mounting bolts and washers, the driveshaft washer and bolt and the keyway.
This clutch has a single wire to connect to PTO switch power. The ground is obtained from the chassis. If your tractor has a two wire connector, just connect the blue wires.
The price is $125 plus any shipping cost. Located near Buford, Ga.
Send me a PM if you are interested.
