I bought a mid 80's John Deere 314 when my wife and I bought our house about 2 years ago. The first fall and summer it ran pretty good, had one small issues that I got fixed at the local shop. This summer I started mowing with it and started having repeats of what we had fixed as well as new things. It would run 15 or 20 minutes and then act like it was running out of fuel sputtering and die. We thought perhaps since I had a crappy cap on my fuel tank that junk had gotten in the tank. So this spring he removed the entire fuel tank, cleaned it all out, replaced the shutoff valve on the tank as well as all the fuel line and the fuel cap. That didn't fix the problem. We then discovered that the electronic clutch was shorting and back feeding into the coil. So we then replaced that and thought we were all good. He ran it and it seems to be fine, but he dropped it off at the house and I started mowing with it and it did the same thing. The two solutions he came up with with the fuel pump being faulty, which I seemed to have ruled by gravity feeding it from a Gatorade bottle and it is still doing the same thing. The other thing he though it might be was a baffle in the muffler loose which would bounce around and block the outflow of exhaust which would coke it out, but took the muffler off and it didn't seem to help much. Ive dumped like $500 into this thing this year and I want to get it running but I am kind of tired of these wild goose chases and dumping money into things that I'm sure have helped but aren't the underlying issue. I have the service manual but too be perfectly honest I'm not the most mechanically inclined guy. I can make just about anything out of wood but when it comes to metal or engines I struggle. Any advice would be greatly appreciated, I'm about at whits end with this. Thankfully I have a finish mower for my tractor so my yard isn't 8' tall yet.......
