Required Minimum Tractor Ballast
CAUTION: To help prevent the possibility of personal injury or death caused by tractor/loader roll over, DO NOT operate tractor/loader unless it is equipped with proper ballast.
The amount of ballast listed in the chart is the minimum required for normal loader operation. For some operations, additional ballast may be required to maximize stability.
IMPORTANT: When adding ballast, do not exceed maximum tire carrying capacity shown on sidewall.
REQUIRED MINIMUM BALLAST
1 -- Fluid-filled rear tires and 350 kg (772 lb) of 3-Point Hitch Ballast (1)
2 -- Three rear wheel weights per wheel and 350 kg (772 lb) of 3-Point Hitch Ballast (1)
If loader is equipped with pallet fork attachment, 85 kg (187 lb) of additional ballast is required.
1 See ADDING BALLAST TO 3-POINT HITCH in this section.
OUO6038,00020C8-19-20120518
