Hi clbeasley1980.
Can you provide more info. I.E. one speed, does that mean you can only shift into one gear, etc. If so, what happens if you try to or shift into another gear?
With the PTO does the tractor run/drive fine under load without the PTO - i.e. if you go up a hill is it bogging down or does the engine stay at a constant RPM?
More detail will help narrow down what it might be.
You can also buy the service manual here:
http://techpubs.deere.com/deere/Default.aspx
It includes troubleshooting, adjustments of the PTO and other areas, how to repair the transaxle, engine, etc.
