I just pulled my 212 out of storage to get it ready for my local steam show. it ran fine when i put it away. here is a video... it also has been kicking back
When I had a similar issue with my 210 it turned out to a wire going to the coil + side was making contact with the engine tin, causing it to ground out.
I’d check the coil, condenser, and points. Good luck.
i just checked the spark. spark is consistant and good. would a head gasket cause these issues? it is blowing smoke from under the tins. it idles fine but acts up when i rev it.
thanks everyone for the replys. here is what i have found... i cleaned and gaped the points. the points are only a year old. i was cranking it over and saw that the spark plug wire by the boot on the coil was sparking to the frame of the tractor. i figured that was what was wrong so i changed the wire. it did stop sparking but did not solve the issue. so i gave up for a little while and worked on some other stuff. i thought i heard my neighbor watering his flowers. but glanced at the tractor and noticed my coil was smoking and leaking. i dissconnected the battery and it stopped. i checked the battery voltage and it was 18 volts!!. so my question is, would that be the source of my issues? like i stated before it ran great when i put it away. what else would i of hurt besides the coil. Thanks
Well first first replace battery, then check coil both primary and secondary (resistance), possible short in coil. Finally then check charging circuit because you over charged the battery!
1 - 8 of 8 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
