1 - 20 of 32 Posts
Im looking for a snow thrower for the JD 170 i just bought. im not sure what model(s) work for it. Any info would help.
Certified Master Tinkerer
The 338 is the main model that fits. When buying used make sure you get ALL the necessary parts including:
mule drive
two draft arms
tensioner spring and linkage
auger lift and spout rotation linkages
You wil also need the ballast weights that mount on the rear.
okay thanks:thanku:, i hope i can find one for a decent price, i would really like one b4 winter cuz i have nothing
oh yeah i found a few but they are all too far away :(
Herd Need a picture of the back side of your 338 where everything attaches to it. ( getting confused, got some more pieces to the puzzle)
Might also help jd926 ID what he should be looking for. Thanks !!!
I hear you I had to buy a crappy 175 with snow blower to get the snowblower but now I have a parts tractor or fix-me-up and extra mower deck too.
Back side - like detached? Might have to go to LTG for those since mine is mounted on my 180. I have pix of the lift and rotate linkages if that's what you need. Can I buy a vowel?
Just takes patience, I bought one for 200, had none of the parts. :crybaby: Luckily the seller was a standup guy and let me bring it back for my cash.
Then I found another one with a nice clean tractor, but the engine was making some noise. So I picked the tractor up and the blower and all the parts for 325.
:trink39:
Fall project is going to be to strip the blower down, clean up any rust, and make it cherry. I can't wait to use it the first time.
Herd is right, if you don't have all of the parts it isnt worth anything. The parts are so hard to find, are out of production, and go for almost what a whole blower goes for if you can even find them.
Discussion Starter · #12 ·
okay i think i might have found one im going to have to take a little trip to get it. but what do you guys think? he sent me a couple pictures and is supposed to be sending me a picture of the hardware so i know its all there he is also giving me weights and chains
That is the correct blower, with the newer style chute. Good deal with the weights. While not impossible to find, they aren't an everyday item.
Discussion Starter · #14 ·
im a little confused right now why it looks like the belt is so long...maybe once i see how it goes together it will make sense..?.?
:trink39:
The belt should look long. It has to go around two pulleys at the middle of the tractor and back to the PTO pulley on the engine. Read pages 8 and 9 of KATT's thread where I try to explain the belt routing for the snowthrower starting here; http://www.mytractorforum.com/showthread.php?t=141784&page=8
You'll also get an idea of all the stuff you should get. Best of luck on your Deere hunt.
Discussion Starter · #16 ·
:swow: Wow thats quite the set up... now i need to make sure he has all those parts and hopefully i can go get it:praying:
Left to Right... PO's Home made Suitcase holder ( newer style suitcases ) Mule drive ( make sure you get this !!!!!!!) Mounting bracket ( blower to tractor ) .
Yeah the belt is long the mule drive sits mid-tractor.
Your blower looks mint I'd drive a long way for that.
I just pulled the whole blower apart ( man rust everywhere)You'll be blowing snow while I'm still sanding !!!!!!!!
Discussion Starter · #18 ·
thanks, i really hope he emails me the pictures of the rest of the parts soon so i know everything is there. i guess from what the guy said he had bought it in 89 new he still has the manual that goes with it so im sure he should have everything.
And Herds link to KATT's thread helped alot, i now know how it is SUPPOSED to work.
This is how MTF works. One person asks a question and 50 are watching, some wondering the same thing. Ain't MTF great ??!!
Discussion Starter · #20 ·
It is great!! :thThumbsU Glad i found it to use:trink39:
1 - 20 of 32 Posts
