1 - 1 of 1 Posts
Hello,
Newbie here I have 1020 diesel tractor and I had a few questions I hope all you knowledgeable folks could help me with. I am looking at replacing the o-rings(?) on the hydraulic pistons that push my loader up and down. It currently leaks a little too much hydraulic fluid after using. I was wondering how I can actually get the thing apart to find the oring sizes etc and stuff I need to replace. See image below. Also just out of curiosity how does one disconnect the hydralic lines and (cap?) to the loader incase I ever wanted to remove. See image #2. Lastly I was hoping to remove the radiator and soak it in a solution to clean as it's covered in crud. Can I just disconnect, clean, then reassemble and fill with new coolant?
Thanks for any help.
Green Wood Motor vehicle Line Bumper
Automotive tire Vehicle Road surface Gas Asphalt
1 - 1 of 1 Posts
