The drive shaft bolts to the flywheel and yes the motor will need to be unbolted and moved forward.
InspectorRudy,Be careful if you are driving it now. Remember what is sitting right above the drive shaft "U" joint! Also, there are four spacers that go on the bolts for the engine adapter. On my 400 the guy who put the Honda in it used galvanized pipe nipples that worked great and were the exact length.
