JD X595 parts needed. driveshaft and yoke
702 Views 7 Replies 3 Participants Last post by  Trentofdestiny
hey guys. looking for some used parts for a 2003 x595.
need a hydraulic line AM133355 and driveshaft AM140733
unit rolled down a hill. i may just end up welding on a universal
Motor vehicle Wood Gas Machine Nut
1 - 9 of 8 Posts
How the heck do those things break just from rolling down a hill? Anyway the lines and shaft should be similar to others like x485, x700, etc
well guess my dad got mad and pulled it back to the farm with the gator...... trans lever popped back engaged. maybe?
the new driveshaft from JD dealer is only $390.00 am128697
  • Like
Reactions: 1
If that is what happened then the transmission could be damaged inside. Be prepared for it to not function correctly even after you fix the shaft and line. Now would be a good time to drain the fluid and see if there's metal in it.
for sure, if he has not already. its been sitting for over a year.
That's unfortunate. Although, it may have happened in the reverse order. U-joint gave out, took out the lines, and then rolled down the hill. I would try Fulton Mower Salvage, Haldeman Supply, or Andrew's Mowers & Parts. You might find a used shaft (cheaper and will let you see if the trans is okay before you buy a new one), but you will likely have to get a new line, unless you find a whole parts tractor in a junkyard.
  • Like
Reactions: 1
thanks, I will look into those. i will likely just take the line off and put a new end on at work. I work at a CAT dealer.
That's awesome! Hopefully the line isn't too short now.
These tractors are getting more scarce coming up on the 20 year mark, and a lot of them are beat I'm discovering. I have one now.
1 - 9 of 8 Posts
