Does anyone know if this kit will work on the small hydraulic cylinder on the JD 40 loader? Thanks https://www.princessauto.com/en/detail/1-1-2-in-bore-implement-utility-cylinder-seal-kit/A-p8435919e
No, it's just that the Green Guys are a bit finicky about original applications of attachments. Most GT sized loaders can be adapted to fit most GTs. Mine has been on a MF12H and a MF1655, and the original application was for a GE ElecTrac. These are all very different sized tractors. The one on my even bigger SCUT is the same size.Ok, the loader on the tractor is a 40 though. Different in Canada?
:ROF We must be reading different JD threads! I see many posts stating which model loader belongs on which JD GT, even though the identical loader is available with a different colour original paint job for a thousand dollars less. Most guys want a loader, period. The Green Guys seem to want the specific JD model loader optioned for their tractor.If you can find a shop to rebuild the cylinder I think it would be well worth the money. I resealed mine a few years ago in about an hour and a half. If you are only having seal issues it shouldn't be something that takes hours.
The 40 loaders are very similar to the 45 and there is some degree of compatibility between the 40 and 45. The "Green Guys" arn't necessarily being picky as Bob likes to think... But there are rebuild kits avalible through Deere and it helps to double check the models are being listed correctly. Bob is correct that many GT style loaders fit other machines but it's always good to double check things.
If it was the 1960-1980's you would be correct. Brantly, Johnson, Soo, Kwik Way, Wright Way, Danco all made loaders for Deere GTs.... And yes if you collect Deere GTs correct mounting brackets ARE important. If you just want a loader, fab some up. Since the 90's the 40 and 45 loader were only found on Deere 4-5 and X units. In this case most of the older loaders (brands listed above) do not readily fit the X units. The tractors are too wide.:ROF We must be reading different JD threads! I see many posts stating which model loader belongs on which JD GT, even though the identical loader is available with a different colour original paint job for a thousand dollars less. Most guys want a loader, period. The Green Guys seem to want the specific JD model loader optioned for their tractor.
The seal kit for the cylinders on my SCUT loader are available at the dealer for US$30. I picked up all the seals except the dust seal from my local hydraulics shop for about US$6.50 (C$9.14). I feel quite confident that the dust seal does not cost US$23.50.
When I also calculate the costs of going to the dealer or to the hydraulics shop, the difference in cost is substantially greater, as is the difference in time required.
That's all well and good, I'm just trying to present options to going to a dealer. Yes, I do understand that collectors, in particular, are going to be picky about which loader belongs to which tractor, but most of us are not collectors. We're just trying to have and maintain a loader for the least outlay of available funds.If it was the 1960-1980's you would be correct. Brantly, Johnson, Soo, Kwik Way, Wright Way, Danco all made loaders for Deere GTs.... And yes if you collect Deere GTs correct mounting brackets ARE important. If you just want a loader, fab some up. Since the 90's the 40 and 45 loader were only found on Deere 4-5 and X units. In this case most of the older loaders (brands listed above) do not readily fit the X units. The tractors are too wide.
Going to the dealer is generally more expensive.... And I am certain it would be in this case. However, sometimes the dealer is the easiest option... For example if you don't have a local hydraulic shop... Or you don't have the time to search for all the seals online. My point is leading into a post about Green Guys being picky isn't necessarily the best way to proceed when chances are other posters were only trying to be helpful and use the knowledge they have.......
Hopefully the OP can have the hydraulic shop rebuild the leaky cylinder and he problem will be solved. :tango_face_grin:
