Status
Not open for further replies.
21 - 25 of 25 Posts
Discussion Starter #21
Well I went and ordered the Brinly Cultivator today. After a year of trying to find something used on Craigslist or Ebay close to home, I found the cheapest new one I could find on ebay and ordered it. I really wanted one of the older heavier ones but there is just none to be found anywhere close. I've got some field cultivator sweeps a farmer friend gave me that I will bolt on there to use for row cropping the garden.
tliebKS Here is a pic of the plow shares that I installed on my cultivator, I purchased mine through my local JD dealer for $4.99ea with the carriage bolts, lock washers, and nuts to install them.
http://www.gaequipment.com/Sweep_p/rc100.htm
Thanks for the info. A farmer friend gave me some that are just a bit wider than those. Once I get it I'll put it together and see if they'll work or if I need to get something different.
Discussion Starter #24
My X540 with the JD sleeve hitch and Brinley plow, some day I may get the lifting apparatus. When I used it to plow I moved the suitcase weights to the front.
Bmurph44 how did the X540 do plowing, do you have any video or pics?
X500 with select 44 snowblower.
21 - 25 of 25 Posts
Status
