need info to repair wobbling transmission cooling fan. Can I access the locknut on top of fan without removing gas tank? Thanks, John
It's tricky but with the proper tools it can be done.need info to repair wobbling transmission cooling fan. Can I access the locknut on top of fan without removing gas tank? Thanks, John
stladrill...thanks for your response. Do you think a moveable socket ext will do it?
Thanks again! I'll give it a try.The hard part is to hold the pulley so you can unscrew the self looking nut.
You can reach the nut wit a short socket and a 3/8 ratchet (long handle if possible)
