Hello everyone. I bought a used JD x300 and it has never cut perfectly. I have leveled the deck properly. I will confirm tire pressure today. I will tighten the belt tension today. I will sharpen and balance blades today. I have made a mark where the blade height is on the deck, rotated blade, and the other side of the blade matches that mark (if that makes sense), I have checked spindles for excessive play ...(one side has a very very slight amount of play) I just dont think its enough play to cause the problem Im having. I just wanted to share these pics with everyone. Hopefully someone can tell me if everything appears ok. I included a pic of how bad my lawn looks after a cut. Are the blades close enough to each other?
