JD LA145 Mower Won’t Idle, Revs High
I have a 2010 LA145 with a Briggs & Stratton OHV v-twin 22 gross HP and 81 hours. Once the engine warms up it runs at full RPM and will not idle regardless where the throttle lever is. It will idle properly when I first start it.
Referencing the attached JD “Choke, Throttle and Speed Control Linkage” parts diagram the throttle link (#4) connects directly to the carb throttle shaft and the governor control lever (#10). With the engine off the governor spring (#5) pulls the throttle link down, which holds the throttle wide open. When the engine starts something inside the engine controls the governor gear (#17) which is connected to the bottom of the governor control lever (#10) and pushes the throttle link up, expanding the governor spring, and allows the throttle shaft to rest against the idle screw.
After the engine warms up for 1 – 2 minutes, the RPM’s begin to climb until it is running at full throttle. When this occurs the gap between the throttle shaft and idle screw is very narrow, maybe a heavy 1/16” but it is enough to cause the engine to race. If I lift up the throttle link it returns to idle but only for a few seconds before the RPM’s rise again.
For some reason, JD designed the linkage to open the throttle shaft 100% when the engine is off but the mechanism that controls the governor gear and is supposed to stretch the governor spring is not doing an adequate job when the engine warms up.
I removed the governor spring (#5) and it idles better but still increases the RPM randomly, just not as high. I replaced the spring and maybe it’s my imagination but I swear it now has an even higher RPM at full throttle.
I noticed that the shaft from the engine that the governor control lever bolts onto looks smooth, no teeth. Maybe the governor control lever slipped on the shaft?
Any ideas????
Any ideas????
