Can I use a "regular" John Deere in-line fuel filter for a gravity feed Tecumseh OHV in my generator? Or is there too much restriction...? Genny was running ragged w/only small amount of gas in it then ran good w/another gallon added. I suspect the filter is starting to clog.
If it's gravity feed, you should use the smaller "pancake" filter like on an STX38. I'm not sure if the larger clear one where you can see the element will work properly with a gravity feed. You can certainly try it and let us know. They are a better filter than those other ones.
