Does anyone have the hydraulic specification of JD 6205 tractor? I would like to know its flow rate, l/min or gpm. Thanks for helping.
life is good
The flow rate will depend on the pump it has. Deere has the option of a few pumps. Find the pumps serial number or part number and you can check the JD site for specs then.
life is good
That is the spec for the stock pump.
According th Dtech there were 3 pumps available at that time.
You can order different sized pumps for the tractors.
But if it was ordered by the dealer, that wpuld be the correct gpm.
