Hey All,
Did a search but no matches. My JD 445 was running at low idle, sputtered stalled and will not start, not even crank. There is voltage at the battery, starter, and key switch. When I turn the key I get voltage going into the key switch board. No lights are illuminated on the key switch board at any time. I checked all three fuses, two on the key switch board and the one from the batt. to key switch are all good. Starter turns when I jump it's posts. All being said I'm looking for a likely or common issue with one of the components that may cause this. Any ideas would be appreciated! Thanks!
If it's the $1K+ fuel injection module anybody looking for parts.
