1 - 14 of 14 Posts
It's a 1993 JD 445 that won't turn over anymore. It started fine a few days ago when my son took it out to cut for about 5 minutes. I've had the tractor about 15 years now and maintain regularly.
I've checked other posts on this issue and have tried a few of the suggestions. Here's my issue:
1. turn key, console lights up so battery is good, when middle light goes off, turn key further to start it. It makes a fairly loud steady sound as I turn the key, like it's trying to fire but doesn't.
2. I checked the plugs and there is no spark. I replaced the plugs and still no spark. Oh yeah, when I try to start it, it backfired on two attempts, so fuel is getting there.
3. the seat safety switch was okay, but I bypassed it anyways and still no spark.
4. I always use premium fuel. I also changed the air filter as part of my maintenance.
What's next? The brake has to be pushed in to start it. Is there a safety switch somewhere that is associated with the brake pedal? The PTO switch is fine.
serial # is M00445A011748.
Thanks a bunch
Not familiar with this machine. But if it has a coil I would definitely test it or replace it.
Sent from my SM-N975U using Tapatalk
Rock, Check + side of coil to ground while cranking engine and you should see 12 volts. If none, bad wire or ignition switch. Then check - side of coil to ground. I believe (??) you should see 7-9 volts, then to 0 volts, back to 7-9. If you have this, coil is good and points are good. If no voltage, remove wire & condenser from - side of coil and check again for voltage. If voltage, coil is good, wire to points or condenser, or points bad. If 7-9 on - side of coil, replace wire from coil to plug. Bob
Kish JD 318/420/430
The 445 tractor engine is EFI and full electronic ignition using pulser pickups with an electronic brain called the ECM (marked as Fuel Injection Control Module)
Check the two LED's on the PCB and see if they are both on. If not it will never start. Search for the remedy to getting both lights on. It has been discussed many times here. It is probably one of the safety switches out of adjustment. The two pedals are usually the culprits and moving either one up or down a tiny bit will usually solve the problem.
All three lights on the PCB light up strong, with the middle light staying on for 2 seconds after turning the key. If the two outside lights on the PCB are the test for the neutral safety switch, then it's not that switch right? And since lights are strong and I can turn on the headlights, battery and cables are good right? It's not the seat switch because I jumped it.
Hi Russ, does that mean there are specific tests I should be doing / not doing? Thank you
Discussion Starter #8
My bad, I was talking about the lights on the dash. As for the PCB, I just checked and I get both the green and red light on when I press on the brake to start it.
Did you play with the two pedals? Set the brake and then turn the key to start while lifting the reverse pedal a tad and then pushing down on the go pedal a tad. If it is one of the two pedal position switches then it will start.
Cam gear ever been replaced?
Make Better Mowers
How many hours did you get on the plastic? 1993 was a long time ago!
1 - 14 of 14 Posts
