1 - 2 of 2 Posts
Was out mowing yard when my mower just shut down. Found blown fuse, changed fuse and started mowing again then about 2 min. later mower deck shut down. Mower still runs, just wont engage deck. Checked the 2 fuses,both were fine.
Any help on what and how to check would be appreciated.
One other wierd thing that the tractor has been doing is when it sits for about 4 days it wont start. If you take one spark plug wire off and hold it close to plug, it will fire and spit and sputter. Put wire back on, no fire, take back off and hold it close, it will spitt and sputter for a while then you can put plug wire back on and it will run and start fine. Done this for about 2 weeks before mower deck stopped.
1 - 2 of 2 Posts
