1 - 17 of 17 Posts
The mower deck won't raise on my 445. I pull the Top handle back and it whines, but the deck doesn't move. What might be the problem?
Thanks!!
Hydraulic lockout valve
Sent from the MTF Free App
Low oil.
:ditto:
A low fluid level will also have a negative effect on hydro function.
Another suggestion--change the transmission filter and oil. Over time moisture accumulates in the oil, from condensation. Oil also oxidizes, clogs the filter and becomes sticky. This contamination can affect a small hydraulic system, making the controls and pressure relief valves hang up. If the relief valve does not close properly, low pressure results, one possible cause of your problem. The o-rings and other parts do not get properly lubricated, accelerating wear. It is much cheaper to maintain than to replace or repair.
445MN
Any luck on this, or does the problem still exist ? Inquiring minds (mine) want to know.
David
Been busy with other "must do" projects. Did get around to checking the oil level. it is fine. Although i discovered the seat will not slide forward to make easy access to the dip stick. The seat seems to be locked in place; even when moving the release handle.
Back to the hydraulic problem. Should I look next at the lockout valve? If so, where is it and how do i go about fixing it? Keep i mind that I am very mechanically challenged.
445MN
Any updates, or did you give up for now ? I hope you get it resolved soon if you haven't already.
David
The lockout valve is down where the front hydraulic hookups are. It should be a t-handle valve. It should be open/close just like a regular valve. Did the deck operate properly before?
Discussion Starter #10
the problem is not yet resolved. I finally looked for the lockout valve tonight. Looked around the four hydraulic connectors under the left foot rest. No T-handle valve in sight. A picture or diagram might help.
Should look like this.
445MN
Hopefully this shows up, but this is the lockout valve.
Discussion Starter #13
The pictures helped. They confirmed I was looking in the right place. There is no valve there. Only an elbow in the pipe. Now what should i do to try to fix the problem?
445MN
You could pick up a valve on EBay.
Keep working the lever back and forth. They sometimes stick on this tractor if they have not been used before. If this is a recent problem then:
1. Have you had the deck off/on recently and was it hooked back up correctly?
2. Where was the deck height set at? If you had it pretty high the deck won't move that much.
Is the height adjustment cranked all the way down?
Discussion Starter #17
it has been a while; but i though I should let you all know what the problem was. In this case we were thinking too hard. It was very simple. I'll start about two weeks before I noticed the lift didn't work. I noticed a pin on the recently installed 3 point hitch was about to fall out. I put it back in and installed a new keeper pin to hold it. A couple weeks later I noticed the lift didn't work and asked you guys for help. Much to my surprise none of your suggestions seemed to help. I just lived with it as it was for a few weeks until i noticed the end of the hydraulic shaft sticking out - not connected to anything. I removed the pin i had put back in, fed it through the hydraulic cylinder shaft, and WOW - it works now. Very simple solution. Just remember i am mechanically challenged. Anyway, thanks for all the help you tried to give me.
1 - 17 of 17 Posts
