Does the tractor still drive?
Sent from my SM-G960U using Tapatalk
How would I bleed the air out of the system? Just keep moving it?I would think the choppy action would indicate air in the system, or a bent ram.
Agreed. It takes a bit of patience for the first full stroke cycle, but the second goes quite a bit quicker. Readjust the fluid level with all 4 cylinders fully retracted after the second full stroke cycle.Aval, Yup, keep moving your loader arms and bucket, full travel in both directions...down to ground is good enough for loader arms. Keep checking hyd. level though or you'll introduce more air into system! Bib
