I am going to change the transmission fluid and got 6 qts and filter from dealer. I removed the seat/rear fender and confused about location of the drain fill plug. I also have a sight glass tube on the rear and don't know where the level is supposed to be. Also, does it share the rear transaxle housing for lube or does it have a seperate drain/fill? Does the transaxle use a gear lube and not a hydro fluid? Help please. Here is what the rear looks like with the sight glass.
thanks for all the help.
