thats good to hear.. I may be on my own but the lift gate is not too high.I can move (carry) it around by myself. It's heavy AND awkward. Easier with 2 people - especially loading in a vehicle without scratching anything. I can be done with one person though
Got it. I just put the back blade back on to do a little gravel grading and I left the mower on and could see the trouble it was causing the deck if nothing else. Lock out valve seems a necessity, but maybe two machines: one for blades/blowers and one for mowing and baggingFrank, A 318 is an H2 system...meaning 2 separate hydraulic system, kinda. Your inner lever controls your front right (as siting on the tractor) outlets and your outer lever controls the front left outlets and the deck plus the 3-pt. A lockout valve on the cylinder for raising & lowering deck & 3-pt (located on the back left side of the tractor looking at it from the rear) will prevent movement of the deck & 3-pt when the outer lever is moved, like if you've got a blade on the front and want to angle it.
As far as the deck & the back blade lowering at the same time, they're moved by the same cylinder. You need to remove the deck when using the back blade or the blade when using the deck.
As far as kitchen table or 2 tractors, don't let wifey read this post and just say it can't be done and you just gotta have 2 tractors! Bob
It doesn't stop there! A real good argument can be made that you don't want to be changing between the snow blower and blade in the middle of a blizzard, so each attachment needs it's own tractor. Further, it is always good to have redundancy in winter.Got it. I just put the back blade back on to do a little gravel grading and I left the mower on and could see the trouble it was causing the deck if nothing else. Lock out valve seems a necessity, but maybe two machines: one for blades/blowers and one for mowing and bagging
I can see no end to the reasons to have more than one GT...………! You'd think this was a tractor forum or something!! :sidelaugh
Well I got the sidelong look and the words "you guys are all the same" :tango_face_grin:It doesn't stop there! A real good argument can be made that you don't want to be changing between the snow blower and blade in the middle of a blizzard, so each attachment needs it's own tractor. Further, it is always good to have redundancy in winter.
Pretty soon you'll have reasons for a whole host of tractors. Safety first!
Good PointOne more point. One thing I would definitely do is remove the cylinders, remove the disconnects on the cylinder hoses, and manually push/pull the cylinder rod to empty the cylinder of all oil. The PO could have used a completely different hydraulic oil, so why chance contaminating your system.
Bottom line: For $300, I'd get it...before someone else does! Bob
