I just bought a JD 332 yesterday. The key ignition doesn't work anymore. So the original owner showed my how to start it with a piece of metal wire about 1/8" thick. The motor started right away. But after towing it back home on the trailer, it will not start when I tried to unload it this morning
isgus:.
First I thought I was running out of fuel, added half gallon diesel in the tank, doesn't help. Attached with a battery booster with full charge, still no luck. Engine cranks but it won't start. I have a feeling that engine didn't get any fuel since I didn't smell any diesel while cranking the engine. I also noticed that glow plug indicator didn't light up. But I think it was off while owner showing me how to start the engine yesterday, so I think it is not the glow plug. I don't have access to any service manual right now, and I need to return the trailer to uhaul yesterday.
Doesn't any one know how to disengage the transmission so that at least I can push it off the trailer. I have called two JD service company but none of them can tell me where the disengage lever is. If any one has same or similar model, will you please post a picture if you happen to know where it is? Or any advises to troubleshoot the fuel system? Any help is appreciated!
