Hi Guys,
I've been lurking at the forum reading and learning for a couple of years and now I have a reason to make my first post. I'm having problems with my front PTO on my recently purchased JD 318. Here's why I"m posting:
1. Sometimes when I flip the switch the PTO comes on and the mower engages and sometimes the PTO doesn't come on I can't seem to figure out any pattern as to why??? Is there a certain position the hydro tranny, brakes, throttle and hydraulic lift must be in for the PTO to operate? I've tried every combination I can think of and can't seem to find a pattern to the operation of the PTO. Sometimes it works and sometimes it doesn't. As an FYI before I installed the mule drive and mower deck the battery light was nearly always on during tractor operation. I gave the battery a good charge and the light went out for a little while and then came back on and is now on again all of the time.
2. When the PTO did kick in I did some test mowing for about twenty minutes to see how the mower cut (great) and fiddle with the hydraulic lift and what not. Toward the end of the test cut I could hear the engine bog down and the oil light came on. It sounded to me like the engine was overheating and might sieze due to an unusual strain. I was concerned the pulley at the front of the motor that drives the belt might not be a "free" as it should be. I knew I had plenty of engine oil because I check that before I operate the tractor and indeed the engine oil was fine. What could be causing the over heating?
I did find one thread where somebody else's PTO would work when the engine was cold but not once it was warm and that problem was apparently caused by worn windings in the PTO magneto which was corrected by replacing the PTO. My PTO seems to be working or not working at random despite weather the tractor engine is warm or hot. Bad windings might explain question number 1 but I don't think it would explain question number two.
Any thoughts on this would be much appreciated.
For background info you should know I just installed the mower deck and mule drive over the weekend for the first time. No wonder it's called a mule drive - what a pain in the ***!!!!
Prior to installing the deck and mule drive I inspected all of the components. The pulleys on the mule drive were turning free and I greased the fitting and sprayed both pulley bushings with some WD 40 and then a bit of grease so the mule drive pulleys were turning free and easy with no slop.
I inspected the mower deck and each of the mower blades was turning free and easy with no slop. Surprisingly, when I removed the mower deck covers I couldn't find any grease fittings but it was turning free and easy.
I did inspect the pulley at the front of the engine and that was not turning free and easy. I sprayed the base with a bit of WD 40 and figured that pulley was not turning because of engine compression. Maybe I'm wrong and that pulley is supposed to be turning free and easy as well.
Any help with problems number 1 and 2 would be greatly appreciated. Thanks in advance guys.
