1 - 3 of 3 Posts
Looking for two items:
1. Assembling the hood after paint and forgot where this one particular piece goes. Is there any 240, 245, 260, 265, 285, and 320 owners out there, I need your help.
2. I also need to adjust my hydrostatic drive. It wants to creep when in the neutral position. Also wondering that if when in the Neutral position, shouldn't it roll? It doesn't but wonder if that is something to do with the misadjustment. Wondering if someone out there has the technical manual and they could help me with the adjustment prodedure.
Thanks!!!
I have a 265. I do not understand what piece you are talking. Also there is a lever on the back of the hydro that you should press if pushing the tractor by hand. At least there is on a 265
I found the lever. I am still concerned with the creep though. The part is #24B in the attached image. I beleive it bolts to the same hole as the top hinge bracket to grill hole. That is what it looks like from the picture at least. Do you have a similar part on your 265?
1 - 3 of 3 Posts
