Well today I scared the **** out of my self. In a past post I mentioned I keep my tractor in 4 WD 95% of the time. I always cut my grass one way and I have tons of hills I'll post pictures. Today I decided to try it in 2 WD well as I was getting to the bottom of the hill I hit the brakes and the back tires locked up and I just kept going if it weren't for the heavy brush and trees I let get over grown(for this reason) I would have ended up going a good 30-40 feet down the mountain. I rarely have to use the breaks in 4WD the tractor slows enough when I let up off the peddle. But not in 2 wheel drive.
Now my question do the breaks work off the of the transmission or do they have breaks? In two wheel it seems only the back breaks work in 4 wheel they all work.
I really don't have a good picture to show but the further down you go the steeper the hill.
the 2305 has internal wet brakes...meaning that inside is where the braking mechanism is. with that said, only the drive wheels will brake. if you are in 2-wheel drive only the rear tires will brake, and if in 4-wheel drive all four will brake. not a great setup at all, so for your case i would try to stay in 4-wheel drive on the hills when ever possible! can and has been a safety issue but theres no other way to resolve the issue. i have hills too, and i'm constatntly in and out of 4-wheel drive!!! what a pain in the ***!
No brakes do not work on front in either 2 or 4 wd.....only on the rear.
reason why it works in 4 wd is added weight on front of tractor. I mow the creek bank it has a 45 -55 deg slope if not a little more.. Just wondering were you in low or high range..That also makes a big difference if I need to use my brakes.. Going down beside my house about a 60 deg slope I have forgotten to put in 4wd and I have slid 40-50' before getting control of the tractor..Using the locking diff. helps to some degree if I think of it in time.
Either way you get the pucker factor real quick.
Your right it does scare the heck out of you, :Stop: especially the first time after cutting the same lawn for four years now it just wasn't expected.
I am in low gear almost all the time.
