1 - 2 of 2 Posts
Hi guys:
Me again. This time I have a few general questions about the tractor. Remember this is the first lawn tractor that I have owned so some of my questions may sound kind of obvious to some of you.
1. Should I drive in reverse with the mower deck running? Will this damage anything?
2. How do I remove the deck? I want to sharpen the blades, but cannot figure out how to take this thing off.
3. Should I cut small shrubbery with the mower?
That's enough for now.
Oh and does the site have an owners manual dump?
Thanks all
certified tractor nut
mowing in reverse should not cause any damage but always be sure you look behind you to make sure no one and nothing is there behind you i also wouldnt reccomend running over small shrubs or anyother shrub for that matter as that will dull the blades quicker and may cause quicker than normal wear to the belt and deck spindles as far as removing the deck im not sure as im not a deere owner and not sure about the manual dump either but hopefully ive helped a little
1 - 2 of 2 Posts
