1 - 7 of 7 Posts
I know where this John Deere is sitting. Assuming it runs, (I was told it does) what is it worth with a mower deck and plow blade?
wel fixed and running at least 1000 in that cond offer him 250 ans see what happens
a 14 hp tractor with a starter/generator setup (older) a plow blade, and a mower deck is not worth much more that 500 - 600 in good working shape imo JD green or not ...
I'd also offer the same 250 and see what happens
Sitting in the weeds for who knows how long. Air Cleaner is off so could have mouse nest in there, bee hive, etc.... The hydraulic lift is worth $250 - $300 on eBay if it works correctly. I would probably on give about another $150 for the tractor so $450 would be my Max!
Early year unit: Screened side panels, solid stripe. (if you care)
I don't see anything worth more than $400 there. I know, the 'part it out' argument. In the couple of cases where I was dickering with a seller and he used that ruse, I responded with 'have at it'.
I gave 350.00 for my 1983 214. It came with 2 blades, wheel weights, tire chains, and a 48 inch deck. Also had new tires and a new second gear in the transmission.
1 - 7 of 7 Posts
