FC540V
KAWASAKI
FC540V-CS00
ENGINE: FFC540V154752
SN: M00185B026544
185 HYDRO JOHN DEERE
That is the information I have from my neighbors JD. He pulled me over there to see if I knew anything about what was going on. I found the carb on JD parts AM109291 CARBURETOR. On the top of the car there is what appears to be a vent? That vent doesn't have anything plugging it in the parts diagram but it is dumping the fuel out. As a temp fix I put a hose and plugged the hose as it was suppose to rain, grass was tall, his daughter was having their grad party there this weekend so it needed mowing and it was getting dark. I even ended up helping with my 332 in the dark.
The engine pulses some but it rain. He was mowing the ditch at the end about to finish and it died and couldn't restart. It did seem to smoke some at start up.
History. Doesn't burn oil at all. Just had the fuel tank cleaned and a new fuel cap and fuel pump just last fall and it rain without issue. When mowing it yesterday it did seem as he "thought" burned more fuel then normal.
So-is that a Vent on the top of the carb and if so why is it leaking and if not what next? I am much better with diesels as I am not fond of carbs. For those that would like to know it has ethanol free fuel and has for several years. But it has run ethanol at one time (not starting a war on that-just stating facts).
KAWASAKI
FC540V-CS00
SN: M00185B026544
