:MTF_wel:
It look like the timing is off, did you check the basic timing? TDC (top dead center)? Flywheel key?
I was unable to meet the numbers either. But, a working igniter/exciter gave me numbers that held. The non-working one did not. The bad one started out at a number and went down to 0 in a matter or 10-15 seconds. I tested mine on the bench. This part is for me to possibly be corrected. Your igniter/exciter, coil and stator creat their own electricity. You (battery) only feed electricity to your starter or other aftermarket devices. (lights, radio, heater, etc) Battery is charged by the stator. Spark plug is charged by the coil and the ignitor/exciter.I've tested it as per the numbers in the pdf for this engine. They aren't even close to what they should be...the coil checks out....maybe i'm missing something easy here...i'm assuming the + / - is where the prongs of the multimeter tester are (the case or the terminal) What does the ON 10 Ohm to 40 Ohm mean though? Am I supposed to have something ON? Is this supposed to be tested grounded to the block or independent of the engine? Thanks for all your help everyone i'll get this think licked yet!!
I am still wondering why your compression is so high. Can you turn the motor over by hand with the plug in? Mine tests at about 58 and I can just get the compression stroke to turn with both hands on the screen on the flywheel. I am an average guy, average strength. My opinion though. 100 pounds you probably can't turn it over by hand.Ok...so I just finished relapping the intake valve and checking the lash..now it's all good. Put it all back together...for the umpteenth time..and no go...it just sputters harder now, but now its out of both the carb and the muffler. I checked the flywheel key again...it's not sloppy at all. I double checked compression...now i'm 100+.
So now the intake valve and the timing are basically ruled out (now that it's backfiring out of both endsThe sparkplug is still wet so we are good for fuel.
I decided to go with BOSOX and stladrill and double check the spark strength....and i think we may have the culprit. When i test it by holding the plug near the head and cranking over i only the the odd random spark unless i'm almost touching the head. I'm going to go out on a limb and blame the coil. The only thing that bothers me is that it checks out as per the Kawi tech manual specs. The ignitor just gives me 27 KOhm no matter which way i test it. When i unplug it i'm totally sparkless...i'm going to assume this means that it works. Has anyone ever had a coil that checkout out but was just really weak?
Thanks so much everyone...i feel I'm getting closer!!
I was having a similar problem on my 175 Hydro. After checking everything about 20 times it seemed like the spark was still weak. I replaced the coil($52.00 at dealership) and she runs perfect!Has anyone ever had a coil that checkout out but was just really weak?
or even just the cap at the plug end. you can cut off the original and replace with a screw-on, cheap to try...Many time the spark plug wire is the problem, to much resistance, could be that?
Is the manual give a spec for the spark plug wire resistance?
