Picked up a 14SB at the end of the season, I want to do an oil change before putting it away, does anyone know oil capacity on the Kawasaki motor (without oil filter)? Thanks!
It is not rocket science. Put about a pint into the engine and then add as necessary until it reads full on the dip stick. At least that is what I do on my 14SB. Roger
Roger, Guess I was just curious if anyone had an exact capacity for it. But otherwise your absolutely right, rocket science is not involved here, as with any engine filling and checking works just fine, do you remember "about" how much yours holds? Less than a quart I assume. Thanks
Thanks again Roger, I swore I had seen it out on the web once before, that must have been where I found it. I checked this machine, something was up with it, not sure if water of gas somehow got in the oil, but its all set now, runs great, I understand what all the hype is about how nice these machines are!
