1 - 8 of 8 Posts
· Gotta love power!
I recently bought an Pacer 18"" engine on ebay. It turns over, has spark and all in all in pretty good shape. I know I can get it up and running but need info on things like:
-Compression ratio
-Oil-fuel mixing ratio
-Plug type and gap
-Torque specs
-location of points (if there are any)
and any other info you may have. If I could get a hold of a copy of the service manual that would help tremendously.
Thanks in advance.
dan
  • Like
Reactions: S-Engines NW
· Certified Technician
This engine is similar to the engine on my Jacobsen Lawn Prince, I mix 40:1 with 93octane and Echo Power Blend Oil.
I set my points to .020"
I set my plug to 0.030"
My points were under the flywheel, under a cover.
Thanks so much. This does help a lot. I am tearing into it now.
Dan
These engines were designed to run 16:1
Hope this reply isn't too late...
-Compression ratio
-Plug type and gap
-Torque specs
Thanks in advance.
dan
Good luck trying to find a manual... The Lawn Queen is about as close as you can easily find nowdays...
By the way, I have owned one for many years (in case you were wondering) I am currently rebuilding the starter (which does differ from the Lawn Queen).
... just fyi, this is a 9 year old thread, and DaninWaxhaw hasn't logged into the site since 2015...
I know, just figured I'd expand on what it has.
1 - 8 of 8 Posts
