1 - 3 of 3 Posts
What glue/adheasive is used to hold these seat covers to the base??
Not sure how all the JD seats are held together but the seat cover on the 345 is glued all the way around to the plastic base.
looks like they load it up with glue and insert the seat and hold it in place untill it dries.
well my glue came loose and I am assuming many others with this model seat too, zoom in on the pic at the link below to see what I am describing.
Seat in need of glue
My seat does not have a single tear and is in great shape but is unglued 90% of the way around.
If I knew of the correct adheasive it could be back like new.
anyone? :fing32: :thanku:
Go to your local dealer they should have it, can't think of the name but it works. Can't say that I have seen to many where the glue comes undone.
Usually they get weather beaten and start to crack and fall apart
umm, I probably should have thought of the dealer.
if they have it then I am all set! because the seat is in real nice shape. I think over time the material shrinks and pulls away from the glue, but I also think there is enough slack that if I lather it up with glue pretty good, it will stick for another X years.
:thanku:
1 - 3 of 3 Posts
