1 - 20 of 22 Posts
Plain Old MTF Member
Been a busy man! Wish I had the time, though I will be on vacation all of September.
Great job!
aardvark161
Discussion Starter · #10 ·
To be honest i dont know but from the way its made and welded looks to similar to the tow hitch bracket to not be original so i kept it on. Have you not seen one before ?
MTF Junior Poster Esq.
Those before views show ..yellow deck and some yellow on tractor. Yes, its a Jake, but maybe a Minnie Mo originally? I have a '66 Ford 100 and it came with a Minne deck.
That looks fantastic..
No, I haven't seen that plate mounted on the rear before. Nor have I seen a clutch bracket mounted like yours. All of the Jacobsen and Ford friction disc clutches I have seen in the U.S. are bracketed from the bottom. May have been some regulation in shipping tractors overseas.
Also, I have always seen "screen" used on the left and right sides of the rear cowling or dash. But, a look through the original manual photos show louvered
plates similar to the vents on locker doors instead of screen.
Anyone's guess!
Subsurface dweller
The later Power Drive (PTO) design...say 1968+ ?... eliminated the torque arresting bracket that is mounted from bottom with the thumb or wing screw. They moved it to the top and is thin sping steel saddled over one of the fillister head housing screws. No need to loosen a screw and rotate bracket for belt mounting of front mounted accessories. You simply remove handle (which by this time is a straight tube with a knob similar to shifter and most are chromed and also eliminated the thumb screw in favor of a longitudinal tension wire), flex the plate away from retaining screw and feed belt between the housing and plate, relax spring plate and re-install handle.
Subsurface dweller
Neil J...
Have a look in MyTractorForum's Ref. Library. Simple John has a 1200SuperChief Operator's and Parts manual available for viewing in pdf format. Wonderful stuff. Look at the Operator's/Owner's manual somewhere along pages 11 thru 18 there are several good shots of the handle,knob, retaining wire and spring plate along with the belt mounting instructions.
MTF Jacobsen manual
1200 Chief and Super Chief Owners Manual pdf
aardvark161
Discussion Starter · #19 ·
In reply to attorney barnabus the colur is definatly faded orange, as ive stripped and and removed all the paint can say there is def no yellow all orrange, and as for the tyre they are made by Innova and called Mug Gears size 24/8.5-12, mine has the mesh plates still have to fit those, thanks for the comments fellas
aardvark161
Discussion Starter · #20 ·
Zippez is bang on with the description of the clutch with the spring steel mount and the removable operating arm with the wire inside, thats exactly what i have, i do have the bonnet but needs a lot of work as its really badly pitted and the front edge has rotted through, but gonna attack it this weekend, asnd see how it turns out
1 - 20 of 22 Posts
