I'm posting a page from the series 13 parts book.My scanner seems to have a mind of it's own,and cut the size down,the P/N is 7033293. To briefly explain the "clutch action" , the cable only works to dis-engage the clutch,and when released,the spring pulls the arm, ,moving the "yoke" #15,up against the "bushing" on the "tail" of the chaincase(not shown),locking the discs together.There's very little "linkage" on this series,and,if there's "slack" it would be in the yoke bushings#16,or maybe,wear in the "slot" in the yoke,caused by the "bushing" sliding,instead of rolling.Also,is the arm moving far enough to hit the rear,of the main case,and not letting the arm fully travel?Also there's the question,did you get the disc,with the "liner" a ring of paper like materiel inside the disc?
