Get your kid to hold onto the plug wire while you pull the start cord....the kid will tell you.....:crybaby:
Sorry about the answer......
:biglaugh::biglaugh::biglaugh: That was funny:thThumbsUNow that I have your attention, How do I check a coil on a homelite xl12 chainsaw. It has sat for qite a while so the points might be stuck"hope not". any help would be most helpful. Sorry about the title!!:sorry1:
:banghead3 Now I seen the title, and thought you were posting another picture of me from up in Moline.... :crybaby:Now that I have your attention, How do I check a coil on a homelite xl12 chainsaw. It has sat for qite a while so the points might be stuck"hope not". any help would be most helpful. Sorry about the title!!:sorry1:
OK, with that bit of info I might suggest you try disconnecting the kill switch and leave the wire open (Non grounded state) and see if you have spark. The grounding toggles have been known to short to ground and stay that way. I have found the replacement switches at my local hardware store in a switch display. The last one I bought was about $6.FERGUSONTO35; stoped at my friendly o'reilly's parts store and picked up one,about $7. now I have no spark.Points look god after I cleaned them and gaped(.015) them. Now what is every bodys guess? A $30 condenser or a $90 coil or both...The saw has good compression and ran fine and started good last time it was ran.
