I have a Simplicity Coronet 2690245 34" rider mower - it is giving me fits right now. To start it the brake must be in, as it should due to that plunger type switch the brake linkage/rod pushes in, but as soon as I let out on that brake, it dies. I just take my foot off the brake and it dies. And if it's of any value, I also tried forcing that gray plunger switch to remain pused in (with some good tape), and of course it does not die when I take my foot off because the tape on it makes it think my foot is still on it. And in that mode I can drive it in forward or reverse just fine. But as soon as I pull up on the PTO(?) to start the blade it dies. So, I replaced that gray plunger switch, just in case, and same issue still. I then replaced the RMO switch up on the console that the key fits in. Same issue.
Then also, just to test the seat safety switch, I bypassed it (just to test it), and it still does the same thing. The only other switch I'm aware of is the little plunger type switch down at the back of the mower that is pressed when it's put in reverse, and I pulled it out and tested it with an ohm meter and it seems to be working just fine.
I'm really at a loss here - can anyone give me some direction please? Im partially disabled and using my old push mower isn't ideal, so I need to get this simplicity up and running as soon as possible.
Any help will surely be appreciated!
Thanks!
Thanks!
