I had a broken rod and piston and messed up camshaft in an BRIGGS INTEK 2 CYLINDER...I did the honing...replaced the rod..piston and cam...set the valve clearance..and the engine runs very well..(maybe some slight backfiring at idle) but at high throttle it smokes...is there a break in for the new piston and rings??...would they naturally smoke for a while?...how long??..or have I screwed something up!..also...what if I got the valve clearances wrong?..would that cause some smoke?...I would really appreciate any help
