I have pretty much answered this question for myself but would like you opinion.
I live on 5 acres and less the house and a couple of outbuildings and a 1/2 acre pond, I mow it all. I estimate that I mow 3 1/2 - 4 acres total.
I bought a new Snapper HZT21480BV zero turn mower either 11 or 12 years ago. They promoted this model as a "commercial grade zero-turn for homeowners". I would say that was a pretty good description because it does have a 21 HP Vanguard Briggs engine, a fabricated steel deck, etc. Not sure about the Hydros. The specs say they are Hydro Gear/10A and Hydro Gear HGM-12P wheel motors. I don't know if those are decent models or not.
This mower now has just shy of 2100 hours on it. I don't know a lot about mowers but I figure that is decent for a residential zero turn.
Now my issue. The motor appears to be pretty much shot. I am getting a LOT of oil blowing out. It has the engine case vent made into the top of the right valve cover and it first started by blowing oil out around the rubber o-ring where the breather bolts to the top of the valve cover. Also a lot of oil in the air breather. It still ran and mowed fine but blowing a lot of oil. I was hopeful that perhaps it was just a bad o-ring but I replace it and now it's blowing out around the other valve cover. I can replace that one too but I know that it will just find the next weakest place to leak. I have not done a compression test but I think it's fairly obvious that they rings are likely shot.
I can buy a new Vanguard engine for around $1,000.00. They no longer make this 21HP but they have a 23 that will replace it. My feeling though is that a residential grade mower with over 2,000 hours is going to start needing other things replaced also. If I spend $1,000.00 on an engine, how long before I will also be spending big bucks on deck spindles, hydro pumps, etc. I don't know anything about hydro pumps but would they likely be getting close to needing replacement also?
I've been pretty lucky with this mower. I've never replace a spindle or anything expensive. Belts, one idler pully, one front tire, a couple of batteries and I think a regulator, is all I've ever had to replace on it.
So what do you think? Chance it and replace the motor or is it time to move on? I won't replace it with another Snapper because even though it has served me pretty well, the local Snapper dealers have not. I bought this mower from a Snapper dealer, not a large box store, but I have never needed a single thing that I have not had to order. They haven't even stocked belts for it.
