Integral hitch for JD 335
1960 Views 3 Replies 3 Participants Last post by  Forward Look
Manaul lift sleeve hitch for JD 335
Does any one have the measurements for the JD manual lift sleeve hitch No.BM17626 or BM 23034 that they would be willing to share. A friend of mine would like to build one for his 335. Thank You
I'm Sure any of the Current X500 Owners That Have one Can give You the Measurements(Because its the same Hitch That was used On the 325 thru 355) Because Your Looking at this Manual Lift
One Correct.
Your Not Looking for The Integral Hitch That actually would Work Of the Tractors Hydraulic system Meaning this one
it was made for the 240 thru 285 and 320 But would Work On a 325 thru GX355 300 series:thThumbsU
Thank you for pointing out the difference in the two hitchs Sergeant
... it was made for the 240 thru 285 and 320 But would Work On a 325 thru GX355 300 series:thThumbsU
Is that an educated guess, or do you know for sure that it would bolt up? Just wondering.
