1 - 8 of 8 Posts
I got to thinking about trying a completely different snowblower on the PK cruising CL last week I seen an ad for a PK with a snowblower it was out in Ohio but when looking at the pictures I seen that the snowblower was a Case snowcaster and since I have a 48" Case blower got to thinking about seeing if I could attach it to one of my PK's so I've been fabricating a hitch assembly and I think its going to work This is what I have so far
HPIM1512.JPG HPIM1515.JPG HPIM1517.JPG HPIM1518.JPG HPIM1519.JPG HPIM1520.JPG
Today made good progress on the hitch welded and drilled and tapped didn't get a chance to take pictures of today's work but its getting close to done will clean it up and paint tomorrow then Monday will try attaching the snow blower to the PK then its to figure out the belt length and see what happens
Finished up the hitch fab work did a trial fit on the work bench and its looking good the parts are now in the paint room curing will see about mounting the snowcaster to the PK next week, then its to fabricate a lift cable and a mount for the chute crank
HPIM1525.JPG HPIM1526.JPG HPIM1527.JPG HPIM1528.JPG HPIM1529.JPG HPIM1530.JPG
Today turned out good got the adapter hitch installed on the PK and then attached the Case snowcaster it attached easy and as it should got a cable installed to lift the blower and installed the chute crank and installed a belt but its about 1 inch too short but tried the clutch and the blower ran as it should so tomorrow I'll try a longer belt that I have in the shop and see how it works otherwise its off to town to get one that is right, right now we have no blowable snow what we is iced and hard maybe I won't get to try it this year, you think
HPIM1538.JPG HPIM1540.JPG HPIM1541.JPG HPIM1545.JPG HPIM1547.JPG HPIM1548.JPG
1 - 8 of 8 Posts
