Installed a Dual Spool Hyd valve on PK2
1406 Views 5 Replies 3 Participants Last post by  GB in MN
Hi all, I wanted to be able to have a separate hydraulic connection for use with the GB Power Grader and if I wanted to add hydraulic power angling to the dozer / plow blade. I had a nice small dual spool valve in the parts room so it was a matter of fabricating a mount for the valve and installing it on the tractor.
Got the mount done and painted so I installed the valve and gave it a test and it works as it should, now its to complete the installation.
Vehicle Auto part Engine Gas
Vehicle Motor vehicle Engine Auto part Car
Auto part Engine Fuel line Vehicle
Vehicle Automotive tire Wheel Tire Automotive wheel system
1 - 6 of 6 Posts
... I installed the valve and gave it a test and it works as it should
That's what counts! :thThumbsU
That'll be a handy feature!
Got the installation completed and the tractor back together and its working like it should, I think the 2nd Hyd connection will be handy in the future. May try installing a Hyd cylinder on the plow blade to make it into hydro angling.
Hi all, well today I finished up installing a hydraulic cylinder on the dozer plow blade for power angling and it works good in the shop didn't run the tractor out to try it but I'm sure I;ll get a chance in the future.
Vehicle Machine Wheel
Auto part Fuel line Vehicle Pipe
Vehicle brake Auto part Automotive tire Brake Suspension part
Land vehicle Vehicle Car Tractor Agricultural machinery
Hi all, well on Wednesday I got the chance to try the PK for plowing snow and it worked good and the Hyd blade angling feature worked good and is nice to have.
1 - 6 of 6 Posts
